Discuss YOUR, testing method's in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I'm just wanting to find out, what are your testing methods, as i dont believe that everyone who tests, does it in the correct order. So then...... coff up and tell us what you miss out and what you do first step by step ;) do you have any habits, tips n tricks.....
regards luke
tea on
paper
continuity cpc
continuity ring final
insulation resis
polarity dead
polarity live
earth fault loop
pfc
voltage drop
Amazing how no one has mentioned continuity of CPC's INCLUDING main & supp bonding!
Mind you, if its an upgrade or the like, then i dont bother with main bonding. Pain in the --- most times to get out the wander lead:D
For a PIR i tend to do INS res tests first because this will (hopefully) confirm that everything is disconnected and there are no issues with circuits.
Then i move onto cpc continuity etc etc.
My bad.
Reply to YOUR, testing method's in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Disclaimer: I'm not going to attempt this job myself, I want a professional to do this job properly since I consider it non-trivial and need it...
