Discuss Your thoughts on bonding this gas pipe in the UK Electrical Forum area at ElectriciansForums.net
Hi,
Nice easy one, I have a gas pipe, its metal, but painted, no supply to properly, its just capped, but live.
As for bonding, what would you do? Just sand some paint off and bung a clamp on it? That's my thoughts, whats yours? I know you are meant to only put it supply side, but there isn't one.
No, its just a live supply in the event that someone wants it, there's never been a meter, I should perhaps tap off it into a boiler and a gas hob, just think, nobody would ever know!
You say there is no supply to the property but the gas pipe is live?
If it's live there will be a meter so bond there obviously. If it's dead or redundant test see if its extraneous I guess.
EDIT for above.
In that case do what you suggested.
yes its live with gas in it, just no meter.
I was just wondering what others would do as to bonding it, that was the initial question, would you just remove a bit of the paint?
because its an extraneous piece of metal going into the ground which unless bonded would have a..... I don't need to explain as you know why, but It is was any other piece of metal you would, that's why I ask, theres a plug socket just next to it, metal clad, I'm just trying to cover all bases thats all.
Hi,
sure about this?
dont you mean consumers side?
is it extranious?
prove it with IR tester...
if it offers a potential then bond it....
Don't you bond on the consumer;s side of the Gas meter, there ain't a meter so how can you bond on the consumers side???:hammer:
Sorry i meant Consumers side of the meter, not supply side, my mistake, I do know that. I would imagine that it is extraneous as its been there 50 years and is metal, chances are it is, I will test it, but I can almost bet that it is, you would bond it if had a meter on the top wouldn't you...
you say theres a metalclad socket outlet near it yes....
rite...thats your reference point....
get a Zs on that socket outlet...then IR between that and this pipe....
prove its extranious...or not..
New posts
Reply to Your thoughts on bonding this gas pipe in the UK Electrical Forum area at ElectriciansForums.net
I have a large gym in the garden and it gets ridiculously hot in the summer. I have utilised pretty much every inch of space and do not want to...
Hi, went to have a look at a job today, customer has had gas supply company out (for another issue) and they have commented that the protective...
Disclaimer: I'm not going to attempt this job myself, I want a professional to do this job properly since I consider it non-trivial and need it...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
