- Reaction score
- 13
Afternoon all
I am looking for some advice as on what to with the suppliers earth after a conversion to a TT system.
Current issue is earthing arrangement is TNS, reading was nearly 60 Ohms, reported issued to DNO, they are effectively washing their hands of it as the (based on what the engineer and contact centre people have said) the earthing in the area has known issues with breaks/degradation and the home owner is to supply a their own means of earthing.
house is urban semi, 30s build, and couple things I wanted advice on was:
1 - The placement of the rod - is there anyway of finding out where underground pipes for other services would likely to be when drilling down and put the rod in? It will be a fair bit of graft as most of the driveway is concrete, however there is a patch of lawn (about 2m x 2m) at the front that potentially could be used for the rod, however the run would be about 5/6 meters to where the supply goes into the home and the MET.
2 - The 16mm earth that is attached to the sheath, as this is not providing a reliable earth, what to do with this bit of cable once the rod goes in? Leave it in the MET alongside the TT earth cable? or disconnect this (leaving the TT earth cable in the MET) and putting the disconnected end of the earth into something like a service head block ?
