Currently reading:
UK Wire extractor fan to bathroom pull switch
Discuss Wire extractor fan to bathroom pull switch in the UK Electrical Forum area at ElectriciansForums.net
1964 house old style wiring
Need to wire a extractor fan up
Is it possible to wire the extractor fan to report switch there's 2 red wires in the pull switch both red. one is a permanent live
Can I wire it up to the pull switch some how or do I need to go to the ceiling rose wiring which is in a very awkward place
any help would be appreciated appreciated sailing rose which is in a very awkward place ceiling rows which is in a very awkward place any help would be appreciated
You are lacking the neutral so would probably need to goto the ceiling rose.
It’s doubtful your going to find a switched live at some junction box it’s going to be at the ceiling rose.
The best way of wiring a timed extractor fan is use a 3 core+e from the rose to a 3 pole isolator switch feeding the fan
Thank you all I think your all right ill have to get into the ceiling rose bit of a pain in the bum right under the Eve's but hey ho
Thanks to everybody that replied I'll post another picture when I get to it
Yes you will.
There was a time when houses had a central joint box under the landing floor for downstairs, and one in attic, right at the hatch, for upstairs.
If wired in twin and earth of course.
There was a feed from mains, and a twin running out to every switch, and a twin out to every light.
One big connector with all the lives, another for neutral and a massive one for earths.
and a handful of switchwire connections from each room switch to corresponding light.
Great care not to get those mixed up or bedroom 1 switch turns on the light somewhere else. 🤣
Yes you will.
Tis
Yes you will.
This is what I found
Yes you will.
That would mean you would only have 2 + e at each ceiling rose, this doesn't seem to be the case with OP.
Looks like someone has removed the rose and choc blocked it.
A typical thing that's done when putting up a light fitting that won't cover the ceiling rose.
The cables need to be in a proper enclosure.
If a electrician sorts that wiring
Does any body think it be compatible with a extractor fan that has a fan overrun on it
( continues to run after light switched off for a while)
Reply to Wire extractor fan to bathroom pull switch in the UK Electrical Forum area at ElectriciansForums.net
