- Reaction score
- 17,088
If your using the specified nm how's it your fault if the 1mm snaps?
Think he means if you are NOT using a torque driver and you bust it. Mind you I have been known to be wrong.
Discuss Anyone got Wiha Torque screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
I mean regardless of whether he uses a torque screwdriver or not, if he tightens it to the point that the conductor breaks it is too damned tight!
I guess according to two people I have no electrical experience And my gold card means nothing. Do you think I hadn't notice the broken 1mm and thought owell I will just leave it loose and walk off? I was just advising the bloke that they can cause 1mm terminations to snap under the NM which the manufacturer recommends. Who do you think you are calling someone else's electrical experience into question anyway? It's a bit rude.
Don't think either of us deserve that response, I for one NEVER bring your expertise or quals into question,
I sort of hear what they are saying though. The MCB recommendation may not be the same as the cable manufacturer recommendation so which one would you follow? Or just use your hand and common sense to terminate properly.
nope because the only flat tyre ive had couldnt be changed as the vechical was in a ditch and the boot was obstructedAnyone ever changed a Spare Wheel and got their Torque Wrench out to Tighten up the Wheel Bolts ?
I'm surprised you highly trained God like electricians which you all claim to be don't follow the regs and use one. Baffling
Which regulation would that be then?
Sorry, which regulation number is that?
Don't know you seem keen though why don't you look it up. Seems you don't have much else going on
134.1.1 it doesnt say "installed in accordance to manufacturer's anymore " anymoreDon't know you seem keen though why don't you look it up. Seems you don't have much else going on
if you use the torque setting and it weakens the mechanical strength of the conductor you are going against the regs.
it only advises to follow manufacturer's instructions it doesnt say you should blindly follow them
Reply to Anyone got Wiha Torque screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
