Currently reading:
Darkwood
Staff member
Mod
Supporter
That was the fastest Sticky Thread in history! This should be fun for all of us. (ps I like your rules DW)
This is a house I was working on today, came across this. One word describes it,,,,,, FAIL
Just after taking that I knock a full box of washers and screws behind the cooker and had to pull it out to get them. Needed them or would not have bothered.
Great thread, post them pictures up lads.
Not electrical but still made me chuckle this was a builders handy work who was doing a few jobs while I was doing some electrical jobs,
Spot the mistake!!
What the hell did they use to hold it up in the first place? Bluetack
(sorted out the pics for you btw Guv)
Had their rep come down to sell their wares and all looked good but the product codes were wrong with what they demonstrated. they stated one code was rated at 40k per fixing when it was actually 20k. the fixing had a part that clips through unistrut (now known as the weak link) under load it just pulled through and once one had gone there was no stopping the rest running away. The 40k version actually just omits the unistrut clip and the wire is just sleeved and looped through a hole.
It is not even carrying that much weight by the looks of it. A lot more cables to be installed going by the amount of basket and tray. Thank god it happened when it was still a building site and not a functional building!
Definitely, imagine if it was fully loaded, it was only having a suspended ceiling below it and that was the main exit route with a lot of foot traffic planned and it came down on them, Big claims#!!!!!!!!
That could have turned out to be the biggest cause of electrical death whilst exiting a building the UK has ever seen. Hope that company gets their nuts and bolts sorted out for the next project.
This is what happens when a welder doesn't have his return clamped properly and the 400amps uses the turn table supply earth to return on.... note how its burnt out in its twisted core design.
This is why welding is a massive danger to the integrity of the buildings circuit and equipotential bonding... it can destroy the earth to many circuits leaving them live and exposed in some cases. Many a death has been attributed to poor welding set-ups of the years.
what type of fixing was it?
usually for us its raw bolted unistrut to ceiling then everything else hangs off that
New posts
