Discuss Derating a BS3871 following an EICR C2 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I suppose if it was supplying a fixed rate piece of equipment (I.e. less than 27 amps with correct installWhat is the cable supplying?
It may be ok as it is.
More information is required really such as length, installation method and what it's supplying.I suppose if it was supplying a fixed rate piece of equipment (I.e. less than 27 amps with correct install
methods and seating factors applied) you could say it’s “ok”
Reply to Derating a BS3871 following an EICR C2 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
