Discuss FCU with two outputs in the DIY Electrical Advice area at ElectriciansForums.net
Dave64
I have an FCU, through my conservatory wall.. it was intended to be for a pond pump, but, can I, have a set up where I can use the same FCU, but switch between the pond pump and a light in a lamp post thing? I appreciate any advice!
Is this the same as this thread?
No, but a continuation.. now I'm safe with the FCU, I want to switch between the pond and a lamp
Reply to FCU with two outputs in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
I'm sure this has been asked before, but I just want to confirm: Currently I have a spur leaving a socket in the bedroom, into a 13A Switched...
Hey, I want to use an old xbox 360 PSU- 12V 175W output- for my 12V sup pump (pump/air compressor). When I connected the PSU to the pump...
