Currently reading:
UK Shower switches burning
Discuss Shower switches burning in the UK Electrical Forum area at ElectriciansForums.net
Bob Geldoff1234
I have just been called out to another burning shower switch.Upon removal the wires had been burnt and chared.One thing I've noticed on all burnt shower switches is that the stranded wires haven't been twisted and just put in straight.I always twist the standed cables to make one solid conductor before inserting into the terminal.My thoughts are that the screw only clamps a few strands when they are straight,leaving the other stands either side of the screw.With the load on a shower I feel this is a weak point and hence why they burn out.Obviously it can also be caused by loose terminals but back in the day when shower switches had two screws per terminal,I don't recall having to replace that many switches.Prehaps they should bring back the two screw method?
As @nicebutdim states when terminating cables into terminals they will relaxe after a minute so you need to revisit and nip them up a few times.
Oh definitely, the amount of tails that I come across in consumer units barely nipped up is staggering, I always tighten them, wait a minute, give them a bit of a wiggle any you usually find you get another complete turn of the screw fairly easily.
Reply to Shower switches burning in the UK Electrical Forum area at ElectriciansForums.net
