I have recently had the joys of doing a little lighting control panel and had to use letters and numbers to identify all the cables.
I was told to cut the cable at an angle to help it slide on, this worked fine on solid cables. As for the flexible cables, especially the bigger cables this was taking up so much time.
Is there a tool out there that can help stretch it to fit on the cable with ease?
Thank you
Thank you
