Currently reading:
Electrical issue, Outlets
Discuss Electrical issue, Outlets in the DIY Electrical Advice area at ElectriciansForums.net
ramhad3
Here is my issues. Woke up this am, no power to TV and wall plugs. I used a RT210 Outlet tester and it came back as HOT/GRN REV. I checked all outlets on the circuit all said the same. I checked each outlet and was only getting 120V from HOT to GRN.
Checked the breaker, it's putting out 120V
I then pulled every single outlet on the circuit (10 total) and hard wired them together as a continuous circuit. Still am ONLY getting 120V HOT to GRN. So if there is a break in the Neutral, how do I find it? Thanks.
Reply to Electrical issue, Outlets in the DIY Electrical Advice area at ElectriciansForums.net
