Discuss Fuse Spur connection to C7 in the DIY Electrical Advice area at ElectriciansForums.net
Thanks James. So 2.5mm cable as the supply and the C7 lead as the output load? Do I have to earth the C7 lead? Sorry if that seems like a daft question. ThanksYes, just be sure to use the correct fuse. (Take it out of the moulded plug)
I am looking to install a wall mounted audio system , so wires need to be inside wall.What's the reason for not wanting to use a 13A plug?
Reply to Fuse Spur connection to C7 in the DIY Electrical Advice area at ElectriciansForums.net
