Search the forum,
Discuss How to calculate the current used by a BLDC motor under load? in the DIY Electrical Advice area at ElectriciansForums.net
I'm working on a robotics project and currently we are designing a battery. This battery is dedicated to the motor driver and two BLDC motors. I want to know how much current the battery will draw if we drive the robot at a certain speed. More specifically, how to calculate the speed of a BLDC motor at certain loads and the current required at that speed. Our design has rear-wheel drive and an electric motor connected to a gear system that turns the wheels.
Motor/Driver Links:
1. 36V 4000RPM 0.44Nm 184W 7.3A Ф57x109mm Brushless DC Motor - 57BLR110-36-01|STEPPERONLINE - https://www.omc-stepperonline.com/36v-4000rpm-0-44nm-184w-7-3a-%D1%8457x109mm-brushless-dc-motor-57blr110-36-01
2. Digital Brushless DC Motor Driver 18V-50VDC Max 10A 200W - BLD-510S|STEPPERONLINE - https://www.omc-stepperonline.com/digital-brushless-dc-motor-driver-18v-50vdc-max-10a-200w-bld-510s
Reply to How to calculate the current used by a BLDC motor under load? in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
This is more a challenge to myself and why not for some of you as well. I will try to make it myself alone but... it will be easier and faster...
Hello I am currently building an Ebike and have been working on this for weeks my main wiring diagram is not in this picture but this is a...
Hello everyone, Does anyone have any information on how much current does a car starter motor draw at no load? The motor specs: Power max: 1.4kW...
4K
M
It's not car related but is a 12vdc porject, so hope someone can be of help to me on this project I’m a bit of an amateur photographer when it...
mollydog
M
