Currently reading:
Kewtech KT63 lead setup for ze, pefc and pscc
Discuss Kewtech KT63 lead setup for ze, pefc and pscc in the UK Electrical Forum area at ElectriciansForums.net
Hi gents and ladies,
I’ve just bought a Kewtech KT63, the instructions aren’t very clear on lead setup. When doing a Ze is this a 3 lead test on no trip setting, using the green blue and brown test leads? When doing PEFC and PSCC is this a 2 lead test on high setting. So the blue/green leads connected together on the earth or neutral bar and the brown lead on line?
I have a KT63 though don't use it much now.
No. High current 2 lead test (green and blue joined together) between Line and disconnected main earth, with the installation isolated.
When doing PEFC and PSCC is this a 2 lead test on high setting,
Yes.
Yes regarding connecting leads together. I usually do PSCC at the top of the incomer.
The low current loop tests are 3 wire tests. As above, they very tremendously in accuracy.
This video shows a handy workaround that is well worth knowing.
Reply to Kewtech KT63 lead setup for ze, pefc and pscc in the UK Electrical Forum area at ElectriciansForums.net
