Finally convinced my boss to invest in a wall chaser!! Looking at getting at Makita VC2512L wet & dry extractor unit with a Makita SG1251J wall chaser. Does anybody have this set up? Or recommend another setup?
Got the same wall chaser and use another wet/dry extractor unit, does the job well! Even chased when house occupied and furnished!
The extractor unit I have, has a socket you plug the chaser into and when you turn on the chaser the vacuum starts and then stops soon after you turn off the chaser!
I've used the Hilti DC-SE20 wall chaser which is a fantastic piece of kit. I've used it with a Hilti vacuum and a Bosch vacuum which both perform really well. Both have a tool socket so they autostart with the chaser.
I run the makita wall chaser with a Bosch gas 35 m class vac. Must say its the nutts. Had to adapt the hose as they were not compatible but works great. Can also buy dust bags with a zip so that they can be reused.
