Currently reading:
Replacement required, heating controller 40A Supply, it operates ceiling heaters above the plaster
Discuss Replacement required, heating controller 40A Supply, it operates ceiling heaters above the plaster in the UK Electrical Forum area at ElectriciansForums.net
Ceiling heating was a terrible idea thank god it never caught on.
Absolutely ridicules completely agree, never seen this before but the controller/ timer has failed and requires replacing but I'm not sure if there's anything on the market that I could replace it with, it's supplied by a 40 Amp mcb and the timer would need to take that load. I'm not sure of the current draw of the individual ceiling heaters although there's 4 x 15 Amp breakers and 2 x 30 Amp, what would you suggest?
Reply to Replacement required, heating controller 40A Supply, it operates ceiling heaters above the plaster in the UK Electrical Forum area at ElectriciansForums.net
