Currently reading:
Seaward Solar Survey 200R Meter
Discuss Seaward Solar Survey 200R Meter in the For Sale and Wanted Forum area at ElectriciansForums.net
Seaward Solar Survey is a simple easy to use meter able to record solar pv and solar thermal values of time for use in generation design or fault-finding and reporting.
Links/syncs to the PV150 tester. Data can be sent into Seaward Solar Elements software or to other databases if needed.
Meter works but display is faulty. The first 2 digits of the date do not work as you will see in the picture attached. Also you will need a temperature probe if using for solar thermal as this is lost.
Selling for £35 only unless offered more.
Reply to Seaward Solar Survey 200R Meter in the For Sale and Wanted Forum area at ElectriciansForums.net
