Currently reading:
Sub panel.wiring question
Discuss Sub panel.wiring question in the UK Electrical Forum area at ElectriciansForums.net
Terp393
Hello I am wiring up a 100amp sub panel in my shop the run is about 230 feet so I was advised by the supply house to use 1/0 aluminum, I was told that the breakers at the main panel at the house would not accept the 1/0 aluminum, what would be the proper way to connect the wires I have seen like step down pins that could be used but not 100% sure if they would pass inspection thanks
If you are referring to 100 amps for the panel I would use four # 3 copper wires and install a main lug only sub panel. The wire will cost a little bit more but it’s half the size of copper. Remember that all buildings or shop in your case has to be GFCI protected
Reply to Sub panel.wiring question in the UK Electrical Forum area at ElectriciansForums.net
