Currently reading:
Undersized Water bonding advice please.
Discuss Undersized Water bonding advice please. in the UK Electrical Forum area at ElectriciansForums.net
Been out to price for another CU change this evening and would appreciate the groups advice.
When looking at the job I noticed that the water bonding is undersized at 4mm on 25mm tails so should be 10mm which is not a problem as I can include that in the quote.
Gas bonding has been done and is 10mm.
The problem I have is when I have gone to look at the main stopcock in the kitchen all the pipework has literally been plastered into the wall so all you can see is the handle of the stopcock. Told the client that I would need to chase the pipework out so I could check and upgrade the bonding accordingly but they would not be keen in this as the kitchen was only redone earlier in the year. The nearest place I could put my bonding without chasing out would be at the kitchen sink which is about 2m away from the stopcock.
How would you all approach this?
Well for TNS the minimum is 6.0mm, not 10mm. If you state on the EIC that there are no signs of thermal damage and you consider it adequate then crack on. Your call, your name on the cert, but realistically it's never going to be a problem despite what I posted above.
I don't have the periodical, but I recall the Connections rag, changed its guidance on 'no thermal damage' scenario, to if it doesn't comply, then 132.16 must be observed, regardless of no damage.
The idea being, it might not have had the situation arise before, but it doesn't mean it might not happen in the future.
Reply to Undersized Water bonding advice please. in the UK Electrical Forum area at ElectriciansForums.net
