Currently reading:
Wallbox Fuse Box Lite Single Phase...
Discuss Wallbox Fuse Box Lite Single Phase... in the UK Electrical Forum area at ElectriciansForums.net
Wallbox Fuse Box Lite Single Phase has anyone used one of these?​
I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max.
The Fuse Box Lite is fitted with a 40A RCD and a 40Amp C Cure Double Pole MCB that is linked to an electronic Suge Protection device. The MCB/Surge Protection dives has tripped twice. Could the Surge protector be causing the tripping?
Reply to Wallbox Fuse Box Lite Single Phase... in the UK Electrical Forum area at ElectriciansForums.net
