Search for tools and product advice,
Discuss What is this small voltage between spa water and natural earth ground? in the DIY Electrical Advice area at ElectriciansForums.net
GM-237
I've noticed a strange voltage reading between the water in my spa and natural earth ground. The reading varies between .35VAC and .7VAC. My wife noticed a small shock from the water after inserting her finger in the spa while standing outside the spa.
I tested the GFCI and it is working properly. The strange thing is that the voltage is still present after shutting off the breaker to the spa, as well as shutting off the main house breaker. With the power shut-off to the entire house, and there's no other power source anywhere in my yard, I'm assuming I'm picking up stray voltage from buried lines or possibly the neighbor's home?
The voltage reading is 0VAC when reading from the spa water to ground bar at the main spa panel. But, from the main panel ground bar to natural earth also reads between .35VAC and .7VAC.
Thoughts?
0.7V is unlikely to give a shock. When wet and making good contact it is possible to detect quite low voltages but that seems remarkably low.
Regardless of whether your spa or house panel is powered on or off, there can be a voltage difference between the different points along the neutral wire of the supply, due to the voltage drop along the conductor when other consumers are using current. This causes a voltage difference between the various points at which is bonded to ground and to equipment grounding conductors, and hence between a circuit ground and 'real' ground.
I am sure someone will be along soon with some information on what the NEC says about spa grounding.
Reply to What is this small voltage between spa water and natural earth ground? in the DIY Electrical Advice area at ElectriciansForums.net
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
I’m running a feeder from main panel into spa panel that I’ll mount on exterior wall of house , will run through basement ceiling. Im thinking to...
Good Afternoon All, So I have a new situation to me that I cannot seem to get a definitive answer for. I trained as an electrician and did...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Pool electrical is fed from a secondary sub panel that is fed from another sub panel coming off the main service entrance panel. I have verified...
