Discuss Which color leg (black or red) should be switched for a 240V rangetop? in the UK Electrical Forum area at ElectriciansForums.net
Thanks. Would a Leviton MS302-DS work for this situation?The red and black should both be switched by a suitable double pole isolator.
You need a disconnect for both hot phasesI have a 240V range top that needs a wall switch added (for preventing an elderly person from using it when unattended). The existing feed is one black, one red, one bare ground. Which color leg should I break with a switch? Thanks
Reply to Which color leg (black or red) should be switched for a 240V rangetop? in the UK Electrical Forum area at ElectriciansForums.net
