C
Current Affairs
Continuity of ring final circuit conductors
I would just add
When measuring at each socket outlet the values should be approximatley the same and the value will be approximatley one 1/4 of the Line plus Neutral loop resistance ie (r1+rn) / 4 with the exception of spur's which will have a higher resistance.
Calculation should also be checked again between Line & CPC (r1+r2) /4
I would just add
