Currently reading:
insulation resistance test on shower circuit with neon isolater
Discuss insulation resistance test on shower circuit with neon isolater in the UK Electrical Forum area at ElectriciansForums.net
n180
On a new install of a shower circuit, with a neon isolater, is it better to use choc blocks to bypass neon isolater or would it be ok to just test live-earth (live being neutral and live combined) and miss the live-live test?
If testing just live-earth, would you write it down in details of departures that live-live was missed and would you just put n/a in the schedule of tests under live-live test?
Thanks in advance.
It would not be a departure to test LN-E as the regulations permit this method. If I use this test it is stated in the extent of work and 'lim' is recorded in the L-N test result in the schedule. However I normally use this method only on existing circuits, on a new circuit where there are no worries over unknown connected equipment I will test L-N and disconnect loads/neons. An exception would be lighting where it's likely control gear/drivers etc will already be connected before IR tests are carried out and would be impractical to disconnect.
Reply to insulation resistance test on shower circuit with neon isolater in the UK Electrical Forum area at ElectriciansForums.net
