Search for tools and product advice,
Discuss Smart switch installation in the DIY Electrical Advice area at ElectriciansForums.net
I'm trying to replace this standard 2 gand 1 way switch with a smart switch.
I've put the both live wires into L in and the switched lives into L1 and L2. This is tripping the breaker though so I'm wondering if anyone can offer any advice on what I'm doing wrong.
Thanks in advance!
Are you assuming the two red wires are lives and the blacks are switched lives up to lights?
The lives are not joined together on the old switch, so shouldn't be joined together on the new one.
For testing purposes.... i'd cap off one of the lives. Don't connect it to the switch, but make it safe in a connector. Connect the other live to Lin, and the two blacks to L1out and L2out. See if that works. It just means all the lights are off the same circuit now.
Unfortunately, if its been wired wrong to begin with, and powered up... the fault that tripped the breaker may have damaged the switch as well.
Reactions: DPG
Reply to Smart switch installation in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi, I have a 220v House I want to change this switch to smart switch, but I am stumped, I don't have a neutral so I had to return the switch I...
Hi, i’ve been trying to buy a smart switch 1 gang 1 way but i opened my conventional wall switch and i only have 1 red wire(Live Old UK) 1 black...
Hi, I've bought a "yagusmart" smart switch from Amazon and it has no earth terminal. Although there are no metal facing parts I would think the...
Hi. I want to replace my traditional light switch for a smart Wi-Fi switch, but my current switch has 3 cables, COM, LOOP and 1WAY. Where should I...
