Search for tools and product advice,
Discuss What is the expected rate to replace 25 halogen downlights with LED ones? in the UK Electrical Forum area at ElectriciansForums.net
jimmy23
I'm homeowner and moved into a property which has 25 halogen downlights, I'm hoping to get an electrician to replace these with LED ones, what sort of cost am I looking at excluding the materials?
Without needing to enlarge cutouts, I should be able to find something which fits in the existing holes.
I'm posting here because if the cost is of my reach for the time being, I can just get on with ones we have till I gather some funds without wasting peoples time to come over and giving quotes.
Thanks.
Have you investigated whether they are 230v downlights or 12v downlights with a transformer?
Have you considered just swapping the bulbs to LED?
Yes they are 12v downlights with a transformer, I tried swapping them with a GU5.3 LED but they start flickering, I read Phillips bulbs apparently don't flicker but I thought best to get them all replaced with GU10s and have a fresh start.
I can swap them myself but not sure if this is permitted nor I have necessary knowledge and equipment to test the work.
£250 ish is what I was hoping for, thanks for the replies.
£10 a light assuming no nasties like really short cables that all need extending then the job becomes much longer, £250 would be my best price, I wouldn't bother for less
What i tend to do is simply cut the old light off if there is lots of nice slack on the cables and then stick a click flow on the ends. then flow on a bit if 1mm flex and then flex to light.
15 mins per light
obviously i will be charging for the flex and connectors
Reply to What is the expected rate to replace 25 halogen downlights with LED ones? in the UK Electrical Forum area at ElectriciansForums.net
Done a job yesterday, remove old 12v halogens and replace with mains, gu10 downlights. Fitted some LED gu10's no issues. Got a call today saying...
Hi all, I bought a house and went around replacing the mr16 halogen downlighters with LED lights. The lights are controlled by a Quinetic smart...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
Hi, I currently have halogen downlighting in bathroom each light with an individual transformer. One of the transformers has gone now and I have...
In the bathroom we have a panel above the wash basin with 3 x 12v Halogen downlighters powered through a single transformer. I am looking to...
