Admin
Staff member
Admin
Mod
Message sent by Dan our server and SEO guy, and former forum owner.
URGENT ADVICE: Zero-Day Exploit is Global - EF Will be Shut Down for Security for 24 hours
There is a worldwide hack for PHP versions below 8.2
View: https://x.com/cyb3rops/status/2112616479061667936
Recommendation is to upgrade any site that needs to be online to php version 8.2 and there will be a security patch automatically applied to servers over the next 3 days.
UNTIL THE PATCH IS COMPLETE ALL WEBSITES ONLINE ARE VULNERABLE AND IT IS RECOMMENDED TO SHUT ANY (in cPANEL OR PLESK) NOT MAKING MONEY
Patch should be available in a couple of days. But in the meantime we will be closing all forums for 24 hours while we check what damage can be done with this. Please spread the message to all your web hosts. And even the other forums and things.
As someone could gain access now but not do anything with it for a month or more. It has caused outages with global companies recently.
Dan untold media
Okay panic over, patch installed and all safe again now.
Make sure you've updated all your own websites!
I think depending on the server software type you run would the patch may be installed for you automatically but still worth checking.
We are still being attacked but by a troll, a former moderator of plumbers forums back in 2012 who thinks he is entitled to the forum lol
But this has been ongoing for years and his attacks are minor.
To be clear we haven't been breached with this PHP situation either. We just needed to go offline until the patch (a simple security update similar to what your phones do all the time) was available to install.
It could have been a couple of days but it was actually just a few hours.
Thanks for understanding this was waaaaaay above my pay grade and actually was a set of 2 possible exploits that AI had been used to find. But once it was found it could have been quickly used to gain access to whole site files.
They could have installed something and then you patch, but then months later they simply visit a URL and run a script that can then let them do anything. Usually ransomware attacks.
Forum has been inaccessible most of today.... I was just about to ask if there had been another problem.... but you beat me to it
Okay quick update.
Basically humans made PHP code, the language most sites including amazon Facebook governments NHS military banks the lot, alllll use and have used just fine for years.
AI got asked to check the code for exploits. It did, it found a lot. Once they had been found there needed to be a way to tell website owners to update their php versions. And there needed to be some time to at least release a version that closed some gaps let's say.
So it hit the world and felt like a hack. It was NOT. Nothing so far has been hacked using said possible exploits.
Couple of weeks on here we are with another update that has been applied already across our servers, that didnt just plug the holes for now it has actually changed the code fully so the exploits dont exist at all anymore.
No need to worry. It was important and we did need to shut the forums all at the same time while we downloaded checked and then installed the exploit temporary patch. But it was minor in comparison to somebody taking control of the server or even worse, it appearing like nothing happened and then next year we get ransomware shut down or something.
So it was just the right thing to do at the time.
Thankfully some people are using AI for good things. But there are people using it for nefarious reasons. The only thing we can do in the development community is stick together and keep updated. Back up two different ways. One on the same server but separate hard drive, one off the server - whether a backup you download weekly or monthly or some cloud service maybe.
But they say unless you have 3 copies of a document or website it doesnt really exist. As a backup can be taken of an exploited website easily before it activates. Then all your backups from then on are useless. And the backups usually overwrite the old ones as disk space becomes limited etc.
So I hope you were not too worried but if you have a website for your own business, and were a bit worried, then you had the right amount of worry 😉 😜
It did need quick action because once it was global news; bot network owners quickly started to deploy bots trying to get into code in files and insert their own bits.
Think I watched Sky News or something last night that showed the amount of hacks / downtime (different things sometimes connected but not always) and exploits being used during the time did all change but all went back normal quickly.
The one graph that was impressive was the amount of exploits being found shot up in 2025 and tripled in 2026. But thats a good thing it brings it out into the open so coders can fix it and shut the loop hole down etc.
AI helped with that.
And its really just processing power. Ignore the artificial bit. Its real processing power they have on super computers that have some time dedicated to just finding cancers, exploits, people's faces if you are in Palestine and Israel storing faces on Amazon AWS then using their compute to go find all pictures with said face in. To then bomb i assume.
So bad stuff goes on with this super computing power too. But this php thing wasnt one of them.
And at no point were we here on this little forum a target for anything but the usual plagiarism lol
