- May 25, 2011
- 6,161
- 7,152
- 10,256,798
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Got a job to price up that's a bit tricky trying to make economical - if anyone's got a good idea then there's beer to be had!
Big warehouse environment, needs a complete lighting revamp and new install of many (haven't finished the planning but around 200 odd) 6' strips (as per customer, I have also suggested looking at LED). Trouble is that it's going to have to be done in conduit not trunking, and the customer wants it all to be multi-zone switched so that it's only the specific pick area that's lit up at any one time, plus the usual EM's etc.
So, I've got 25mm conduit (maybe 32 at a push), most likely PVC for cost, a heap of fluorescents, bunch of switching, and a BRB that tells me I need to use 16mm singles for voltage drop compliance over 200m (length of warehouse from the main DB). Using 4mm single over that length you lose 2.2v per amp, so it's just about possible to squeeze 2kW and more or less be within the 5% but I'm then wondering about the inductance spikes of that many fluoro's going on and off.
The only immediate thing I can think of is to divide the whole lot up into a load of submains and use separate armoureds to supply each one, but it's going to push the cost way up and I don't think the customer will stand it.
