i=p/u
How’s it going people, have a wee problem with danfoss fp720…
I don’t know if timeclock is faulty. I put connections in 3&4 Like the last one but it ain’t right or it’s faulty… any help appreciated This fine Sunday
After messing around doing a few tests, I’ve ended up with faulty time clock and the valves seemed to be jamming, which I removed pins and sprayed with wd40. All good then ye say
but now it seems that the upstairs heaters is coming on with hot water
From reading, a check valve could have failed or valve could be leaking internally , back to plumber I thinks. Can’t think of anymore maybe you can🤷‍♂️
i=p/u
Northern Ireland
United Kingdom
Danfoss fp720
Central Heating Systems
Thread Tags
Tags Tags
danfoss
i=p/u,
i=p/u,
