Deleted member 9648
Currently doing an ensuite upgrade for a mate...(underfloor heat mat/digital shower etc) in a house built in 2004.
When I first fixed I did a bonding check...none visible on the gas but a 10mm left the DB in that direction and as the pipe entered the house behind kitchen units I reasoned it was just not visible..continuity showed 0,02 ohms...good enough for me.
Water though was a different story,stopcock readily accessible but no wire....continuity check....zilch. "Have you got a cert?" I asked.
Eventually tracked down it was an amtech cert completed by a local contractor whose vans I see regularly.....Main bonding...Cooper(!)...10mm ...gas and water ticked,just to prove the bonding wasnt a one off the main earth was also Cooper(!!)...16mm,and the supply tails were also apparently Cooper....25mm.
Looking at the alleged test results revealed 5 rings with end to end readings dutifully recorded...ring 1 L-L...0.3 ohms N-N....0.3 ohms E-E....O.3 ohms(!),odd as wired in 2.5/1.5...............Even more odd was the readings for each and every ring was exactly the same!........Amazing,they must have spent ages carefully making sure each ring had exactly the same cable legnth!!
Reminds me of the one I saw a while ago with RCD trip times recorded on the cert....despite the fact that there wasnt an RCD anywhere in the house...sheer genius!
God 'elp us....you just despair.
Anyone else come across any LOL certs ?
