J
jimlin
I'm about to fit a pottery kiln which is rated at 15Kw. It's on a 240 volt supply.
By my reckoning that give a current of 62.5 Amps.
There is a 63 amp type B MCB in the consumer unit.
There is also a 63 Amp switch on the wall fed by a 10mm square cable.
Will this be enough or do I need to fir a bigger MCB, witch and heavier cable.
