Darkwood
My boiler broke down last night (not the other half), no H/W and has been intermittent when calling for C/H
Now this isn't my usual field of play but hey its all electrically controlled at the end of the day, so after a few hours of dibbling and dabbling and a downloaded installation manual I figured out how it worked, what was wrong and what needed servicing while I was there...
Required new control PCB and was quoted over 140quid for a boiler thats probably 15yrs old ... well they can go kiss my hairy harris I thought so stripped the board out and traced the circuit tracked from the terminal inputs to a failing pcb mount relay that brought the C/H on hence intermittent, the H/W issue was a failed diaphram in the H/W manifold.
Cost of relay £2, cost of diaphram £4
Cost of service parts that were intermittent and due for replacement - £80inc' (diaphrams for HW manifold, flow valve and diverter + pressure differential switch for monitoring air flow)
Boiler working again and although it could have been achieved with £6 of materials I went all out on a service and saved at a guess £400 - £500 callout for diagnosis and repair.
If anyone points out I'm not Corgi-registered, all I can say is the gas side was never touched, I'm more than qualified to diagnose and repair the control side (even more so than most registered plumbers) so sod the red tape on this occasion, it was my own boiler and of course I wouldn't be doing it for customers.
I shall consider a new boiler next year after seeing the state of the heat exchanger and not worth the cost against a new more efficient boiler.
mg_smile:
