Midwest
As my old trusty paint stripper heat gun has packed up, can anyone recommend a gas cartridge one. I bought one of those that use a zippo lighter from ebay, and could never get it to work.
Was gong to buy a HellermannTyton E4500, till I found out the price of £117.
Anybody got any sensible suggestions? Or should I just get a blowtorch from B&Q?
I use my Portasol pro soldering iron. It even comes with a clip on protector to protect the surrounding area.
PS . Around £85.
Yes , it has a tube attachment that turns it into a heat gun; no flame just hot air.
It also has piezo ignition, plastic knife , high flame torch , it will solder copper pipe fittings and is one of the best soldering irons you can buy.
i just get the ex-wife to breathe on the heatshrink.
Try the CPC website for the micro therm IRODA gas torch - amazing little thing that uses a standard lighter and has a heat deflector for accurate work. Only 10.99 - I'm waiting for a spare 10.99 before I get one believe it or not! Unless anyone can review its efficacy then looks like a keeper.
Set is like this.That is the hot air attachment that is on it.
I bought one of these a few years ago. I found it absolutely awful.
Not all standard lighters work in it.
Even with the right lighter in it it was quite temperamental.
If used for too long the whole thing smelt like it was going to burn.
After a while (few months) it fell apart.
It 'looks' perfect for heatshrink but it really isn't.
i coil some scrap 1.5mm bare copper wire round the heatshrink, then connect the ends to a 240V supply. fed by a 16A MCB and RCD protected, i then switch on through an immersion heater timer bought from azamon at a silly low price, made in china, set for 3 minutes, time enough to imbibe of a pint of glorious hobgoblin. if the heatshrink survives and passes IR and continuity tests, wrapp it round with 2 layers of insulating tape (as per manufacturers instructions from B&Q), then bung it into a void , never to be seen again.
That's a good method now that copper is cheaper. So is it a pint to a joint. I would hate to go against the instructions.
I had one but it didn't last long. The ignition failed.
The mini heat guns with lighters are OK for an emergency heat shrink, they do work, slowly, but are not long lived.
I use a paint stripper heat gun for heat shrink about £20, but do require a power supply.
You can get cheap and cheerful gas soldering kits for about £20 and this is my lack of power supply choice for heatshrink.
Try cooking utensil shops
Creme Brulee burners are just a cheap gas torch, mine was from a chain called "the Range"
Got piezo ignition and refillable with lighter gas, had it for about 3 years bought another as a spare a few weeks ago it was £9.00
Crackin' idea edexlab - probably use it as often as I make crime brûlée so it'll last a lifetime - and I mean that as a positive.
I use a crime brûlée gas torch, had it for I think 4 years now, works perfectly, very accurate and controllable and lasts ages without refuelling. Only about £20 of eBay I think it was, it's really good and quick.
Your just being ridiculous now.
well, having forgot the chip pan was on, and almost burnt the house down, think i can afford to be ridiculous. still coughing from the smoke inhalation. fire brigade chap said i should have got out instead of tackling it. silly sod. as if i'm going to run off and leave 3 dogs. anyway. not as bad as it looked. a couple of kitchen units scrap, along with the cooker hood. smoke damage that a couple of coats of dulux will fix. happy days.
edit: and it's you're.not your. :hammer:
That's awful - can you blame the Hobgoblin or was it just you being an Arsenal?
Well its you're :winkiss: own fault, fried chips are know to be dangerous to health.
Edit: Use a capital letter to start each sentence, and after a colon if the introduction is short and the words after the colon are the main idea and a complete sentence.
:6:
Thanks for your're replies chaps, I'll peruse them later.
I got something similar from ebay, but could never get the cigarette lighter to fit & seat into the gun. This one works okay then?
Couple of bad reviews and one would use in an emergency. I think the idea of the Creme brûlée torch for very little money or the blow torch style if you have the extra cash - it's always good to buy quality that lasts if you can afford it.
can'tblamethe beer.i was on the first one. as it turned out, that was the only one yesterday. i was working on a quote and just forgot the bloody pan.
Good to know Geordie thanks , to be honnest bought it over a year ago around 90£ inc gas can cylinder.
Aye ... the Rotherbergers are around £60 - £80. The gas is about £12.
Like everything else, it depends on where you go and what deals are on at that time.
:6:
Nah, nah, nah!! It's YOUR own fault and Thanks for YOUR replies!!! YOU'RE lucky to have me here to keep you right. :19:
Midwest
Oxfordshire
Retired Electrician
Hot Air Gun for Heat Shrink
Electrical Tools and Products
Midwest,
Midwest,
