J
JakeC
This might sound abit stupid but can you get blank sections to fill the space in a consumer unit for unused MCB's?
For example most consumer unit deals now come with MCB's that won't need to be used. Hope that makes sense.
If so what are they called? Cheers
Although the GE blanks above are generally universal and will fit most DBs. The DB manufacturers own blanks often fit more securely and look neater than the universal types and therefore should be your first choice. Any electrical wholesaler will be able to source blanks for all of the major manufacturers.
You also get the banks that clip in the box lid as well as the type that are the same size as an MCB and clip on the rail. Any wholesaler should have a variety.
IMO the MCB size ones that clip over the bus bar are much better as they can only be removed with the db cover off. More expensive but a much better job.
Ok so your not an electrician I see from your previous posts that you seem to be either learning or dabbling in electrical installation work I stand correctedc and have removed old post Appoligies for any offence caused
I will leave the MCB's in the box that don't serve any ciruit and mark them "unused" - they are the property of the customer.
Good lad !!
In my early days on this forum, the issue of what to do with the "spare" MCBs was discussed & I jokingly said I sold them on e-bay.
For that I was severely rebuked by our Friend Tony !!! .... I think we're ok now though :17:
