Discuss Pet hates in the Australia area at ElectriciansForums.net
I thought they were just there as a cheesewire?imbeciles that cut cpc's off=== because they don't do anything, do they.
parking your van out of the way so you are not asked to move it and half way through the day someone says"can you move your van?"
Twisted cables usually earths or all the earths in 1 sleeve
I also found recently I had bad continuity results and tugged the cables in all the sockets and they did not move but found after two hours that the twisted together cables were lodging on the screws, but the screws were loose, thank you someone!absolutley my pet peeve too, bad enough in sockets, but when you have to pull apart a whole fuseboard just to get an R1+R2 on one RFC :banghead:
Dirty would be clients giving your quote to another to see if they can do better. Total ******s.
plumbers, builders, kitchen fitters that think they can install electrical circuits.
Members of MENSA shouting their mouths off.
hilarious...
must be intending to smother cables in itchy-poo. allowing for de-rating.Builders saying: We will install the lighting ring....
More a case of what they have not done, like label the distribution board.
Reply to Pet hates in the Australia area at ElectriciansForums.net
