E
Edd
Ah so you have taken a twin and earth from the CU to the first sw, then a 3 core+e to the second and then a twin and earth from the second sw to the lights? If so then yo will need to block the neutral blue to grey of 3core. then brown and black of 3core in l1 and l2. brown feed from CU into common. then at second switch block the neutral again and do the same but this time the common will be the feed up to the lights...
failing that do as tony says
