After some trial and much error I've settled on Wago connectors with the IP20 Q12 junction boxes you can get from Toolstation - and sometimes the LINE junction boxes when the cables in and out can't easily be clipped - for downlights, etc.
I've pretty much given up on Wago boxes - they're far to cramped, or maybe I just lack the dexterity.... I'm convinced there's a design tolerance problem with the newer smaller 'Light' Wago boxes as I struggled to get the lid closed every time - even on just a couple of 1.0mm2 cables.
Same. But I make it even simplier without JB's. On new work, neutral looped in switch then loop in and out into i-cage lights - they have room for 2 x 1.5 T&E
well thats what i plan todo, just use the wago junction box to take l-n-e too, then loop the lights, will 2 x 1.5 heat resistant flex fit in these connection built onto lights????
