S
snowplough
Many thanks for that reply ,ill try and get my head around it.
Second question, in a single load circuit say alioght boulb in the house, if its supplied b the normal 230 volts if ou measured the voltage just across the light bulb wire would thi measure les then 230 volts , and if so what would it measure. after the light bulb if oumeasured the voltage in the netral wire would this measure 230 volts or would the voltage or pressure now be less because it as loss presure going throught the light bulb. If you measured the voltage at an two points in the line would this meassure 230 volts just before the load?.
Hope u can answer this as i am a little confused.
Regards
Snow plough
Regards
Snow plough
) When they are at a certain `pressure` (say 230v) they`ll escape to somewhere where they are under less `pressure` (0v) if they can. When you close the switch contacts in your lighting circuit, they have a path to a place of lower pressure, so they take it. That results on them passing thru the filament & lighting it on the way.
) & drop in various resistors in series. Measure to destruction between the various parts of the circuit until you can confidently predict, knowing the volts supplied/resistance offered, what the voltage will likely be if measured. (remembering that the source voltage will be dropped (shared) betwee ALL the resistors in that series circuit)
