different switching / end use configurations are done via the same cable in controls all the time, i see no problem with your plan...
I’m looking at this from an industrial viewpoint. Many times you will come across cables in control systems that would have multiple points of isolation.
On that basis, I can’t see a problem.
I completely agree Tony, but if your working in those systems, say a rotork valve for example, then you expect to have Multiple points of isolation. On a circuit like the one proposed, then the average joe wouldnt. If its labelled properly then i dont see a problem, but for meitmust be clear labelling. Ie at the switch, light and on the JB's.
I still think one point of isolation is to be preffered.
Agree with Tony's point...add to that required labeling of the installation and alls good. Addition of a single point of isolation for both circuits also improves the situation,putting a 4 pole isolator in place of the first adaptable box (circuits onto the swa) would cover both connection and isolation purposes.
For the sake of a couple of extra holes, or investing in a larger drill bit, I think I run the two circuits separately. In this sort of premises, there's a lot to be said for keeping it simple.
Did think of that but would you use 1 adaptable box for both cables or 2. if its the former that slightly defeats the idea of having 2 cables!
can you do it like this ? yes
would i do it like this ? no
surely the biggest element to the job is digging the trench ? and throwing in an extra cable in the hole isnt gonna take too long.
terminating each end of the cable to do different tasks will be a faff to be honest regardless of your chosen method.
having 1 cable for power and 1 for switching is just more flexible and a better all round design.
I am doing this same situation at home but I am running two seperate armourds down there! One for the power and one for external lighting by the outbuilding! , keep things simple!! Also prevents any criticism off other sparks in the future!
it
isim off other sparks? It'll never stop that
If you are going to run one cable,which I can,t see a problem with then you could use a 4 pole rotary isolator at the start of the armoured so you get total isolation of the cable for maintenence.
Definitely a separate junction box for each end of each cable. Then you can work on one circuit and not worry about whether the other is live. Obviously, if one end of both cables is terminated at a DB or similar, that would be a different matter at that end.
Just have one cable with enough cores, i cant see what the problem is? Am i missing something lol.
