The guy has a couple of youtube videos up, he's not the worst I've seen on there even if he doesn't ever mention testing
It's very naughty to use the cpc as apparently it can stretch and reduce the csa.
I should have put a tongue in cheek smily at the end. It just amused me that most sparkies do it, people post videos on how to do it, yet it's classed as bad practice.
I always do what he said we shouldn't.... score the centre over the cpc, score around the required finish area, slice through the last few mm, then peel back. If you know how to use a knife, you won't damage the insulation.
Hey,this looks like a reasonable way of stripping,my previous method of using a blow-lamp or letting my hamster gnaw it off has been troublesome and less than professional. I, for one,am grateful for this input.....
Many years ago I was taught to stick a Stanley knife blade right through the centre of the T&E and then pull it through to the end. It never sliced into the insulation on the cores. Usually use the CPC now as I have lost my nerve, if you use the side cutters to grip it you will cut the CPC before stretching it in my opinion. I will have to try the micrometer on a sample and see if it makes a difference.
Tell you what, let's all go and get a bit of T&E, take the cpc out and have a stretching competition.
Rules are
1) no blowlamps or airguns
2) no 'one end in a clamp and the other attached to your tool bag'
3) no teeth
4) no spitting
5) no swearing, smoking or heavy petting (for the Geordies that's NOT a big lass)
hmm....i use the CPC...i start it off with the snips..end on.....then pull the CPC through the grey.....thing is..once you have got it started it goes easy...i doubt you`l stretch the CPC on modern cable....just watch the old colour code stuff though as i`v noticed that the copper in some of that stuff is a bit on the soft side....
theres not a chance on earth the CPC will stretch on new T&E, i find older T&E the sheath is alot harder as it's aged, then there might be a chance of the CPC getting stretched but bugger me if thats going to make a difference to the circuit characteristics!
Stanley knife in between Neutral and earth.............angle the blade slightly toward earth wire and push forward and let the wire guide the blade down easy peasy:)
A new blade sometimes bites in mind you so use a blunt one !
Snips end on to split the first 10mm or so, then a decent cheese-wire pull! Can't see me changing to anything else after all these years. I do use the 'crocodile' type wire strippers for conductor cores, especially on stranded, though. Rarely need to set them to anything other than 2.5 as it still grabs 1mm off.
When my next set of snips bite the dust (no pun intended) I might look at getting some with the stripper holes in them, but experience teaches you that you actually can strip anything with snips regardless!!
