You are legally allowed to carry out whatever work your customer asks you to carry out, within reason.
Most electrical work will (if your intention is for it to comply with BS7671) require you to issue a certficate.
Part P of the Building Regulations requires that some electrical work be notified to the Local Authority Building Control (LABC).
It is the responsibility of the person ordering the work, or ultimately the householder to make notification.
There are three methods that notification can be made.
The first is to pre-notify the work, pay the fee and have Building Control inspect the work.
In some instances, the inspections will be waived, if the LABC are happy that the person conducting the work is suitably qualified and will be issuing an appropriate certificate.
The second method is for the person ordering the work, to employ an electrician who is a member of a competent person/self certification scheme.
The electrician will conduct the work, issue an appropriate electrical certificate along with a Building Regulations compliance certificate and then arrange notification through their scheme. It may be that the scheme issue the compliance certificate, or perhaps the LABC, I'm not 100% sure.
The third option, is for the work to be carried out without pre-notification and without employing an electrician who is a member of a scheme. Then to make retrospective notification.
Different LABCs deal with this scenario in different ways. Some will accept an EIC or MEIWC, some will require the work be inspected and an EICR, some will require the work be inspected and a three part EIC be issued.
In any event the third option is the most expensive.
In many instances electrical work will not require notification.
