dlt27
Hi All,
Had a farmer I’ve done some install work for call yesterday saying overload was tripping on his vac pump and could I get some new capacitors ( thought it would be simple enough as changing like for like). When I got there to have a look he said the guy who looks after parlour ( controls etc) had changed the capacitors for 3 new ones, but said they were not the same size and I should get some the same as the originals.
I know the basics of how motor start, motor run capacitors work, but no more than that.
The ones that were taken out ( see pictures) were 2 x 35 micro farad capacitors ( presume for motor run) and 1 x 408 micro farad capacitor with a 15 kilo ohm resistor across it ( motor start).
What I was hoping for was that somebody better educated than myself could tell me;
1 How does bad capacitor cause overload to trip out?
2 Why is there a resistor across the start capacitor?
3 Because I can’t get exact match as long as new capacitors are correct size and voltage can I use any make?
4 Is the start capacitor oil filled as he said terminal box had oil in it?
5 What affect does size of capacitor have on the motor ie changing a 30 micro farad to a 35 micro farad for example?
6 Is there anyway to determine what size capacitors should be used for a motor if you can’t find the info on existing ones?
7 How do you know a bad capacitor, as when I checked the 2 x 35 micro farad capacitors they were reading 29 micro farad so presume ok, but 408 micro farad was reading 0 micro farad.
Sorry so many questions, I haven’t had a chance yet to see the motor as he was milking at the time and just gave me the capacitors.
Thanks again in advance for any information..
