Cherrypicker999
I have a fluorescent light "tube" light in a kitchen that I want to replace with a LED light
There are 5 wires coming out of the ceiling connected to the Live Earth and Neutral on the fitting.
The new LED light I have purchased is plastic so does not need an earth.
I put the Earth wire in a connector and taped it up.
This leaves 4 wires,
1 Red and 3 Black (1980s wiring).
Two combination of black connected to the new LED allow other downstairs light to work, without then in the LED neutral connector they do not work,
I assume they are are both neutral.
I though the red was permanent live, but it appears to be a switching live. I put that in the LED and it works as do all other downstairs lights,
However, one landing light controlled by 2 switches does not work.
That leaves one black cable. This appears to be a permanent live. If I put it in with the red wire in the LED light the upstairs light works, But switching it on puts the kitchen LED on dim and it will overload. The black live has been taken out and isolated. This seems to indicate it is a permanent live and needs to be connected to supply power to the upstairs light.
If I connect the red and black live together (outside the LED) and move one black neutral to the LED nothing works, If I swap the black neutrals nothing works. This implies both are neutrals.
It seems the old fitting had both red and black live connected together. The batten could handle this poor installation and the ballast requirement did not switch it on if the landing light was switched on.
I suspect I need an electrician to connect this black live to a live to complete a circuit to the landing light. This is not a job for me.
My questions:
1. Is my analysis of the wiring correct, or have I done something wrong and there is a simple solution and simple connections?
2. Do I indeed need the black live to be connected to a live for the upstairs light for it to work, by an electrician? Not something I would attempt.
What exactly do I tell an electrician I want doing? Currently the black live is isolated and the landing light does not work.
3. Are there any LED devices that could be used that have a loop or connectors that would resolve my with simple wiring in (I assume a ceiling rose pendant would - but I do not want that).
Any other advice?
Thanks.
My questions:
Any other advice?
Thanks.
