Hi my name is karl of sims electrical contractors. I just started a block of flats and have to install a 12 way ryfield board via a 400amp a TP/N Isolator in a riser cupboard. What size tails should I install from isolator to ryfleld board. All to be enclosed into 6-6 metal trunking
Is that 400amp per phase ?
You are limited to 240.0mm² for a Ryfield board of that size.
The 12 way ryfield will be sub mains to 12 x 100amp red cutouts to meters(being done by southern gas) From there I'll install 25mm 3 core swa to 12 D/Bs 1 being landlords then 11 flats
