Discuss 40mm x 37mm rectangular grommets in the UK Electrical Forum area at ElectriciansForums.net
How do highly you rate this product?
I have some (not this exact stuff) and it's terrible, very shallow on the cut sides.
I've been looking for a quality alternative for a while, and using any spare from the Fusebox consumer units as that stuff is way better than any I have found!
Cheers
Sy
Honestly, it was a google search.
I use some much heavier duty stuff when doing industrial panels but it would not cope with such small rectangular holes as the op is looking for.
Reply to 40mm x 37mm rectangular grommets in the UK Electrical Forum area at ElectriciansForums.net
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
Hi does anyone know where I can source any larger round grommets ? I will be drilling a hole in 100 × 100 trunking so guess around 75mm hole. I've...
Hi all, our summer house had a FuseBox consumer unit fitted last year and the guy who did the work has retired. nothing wrong with the install...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Does the consumer units top knockouts need to have stuffing glands installed even if a 50x50 trunking will cover the holes? Or is it sufficient to...
