S
SPARTYKUS
Hello
Quick one as not somewhere I can look up easily- standard mains ionisation (161i?) -do they or rather should they BOTH go off when one test button is pressed?
think the test button only sounds it's own detector, but stand to be corrected as not 100% sure.
Only have generally worked with Aico's for a long time, but even the other brands all interlinked detectors should sound. With Aico's no matter what you have be it a Smokie, heat or carbon, if interlinked they should all sound. Likely to be a very short delay from the first detector sounding to the others sounding.
Danke schone mein fuhrers. Great aico site. Ta needasparks. Yes it should operate all interconnected alarms. Damn it thats annoying. Its at a family property, not home, was flooded, i know the spark that fitted new smokes. Annoying.
The wireless range need to be paired first for them all to operate
Correct me if I am wrong, but I think they operate ok if not paired up. The trouble is that if not set then any unset radio bases within range will sound - your neighbours and so on.
SPARTYKUS,
D80,
