Takes dumbing down the industry to a new level, i cant see the benefits if im honest. I would rather fit plastic conduit with pipe cement than that kiss me arse product.
It looks quick though....saves all that threading.
I have seen it but never used it I don't see a problem with it. Some may argue the skill has been taken away but what skill, threading a piece of tube? You would still need to form it if necessary and that is the skill.
Seen it a couple of times but never used it, and never will....but if it serves a purpose for you, why not.
I wouldn't fancy it without earth conductor.
The Electric Centre had it in their catalogue for a while but soon took it out.
Looks to be quicker, but how good is the grub screw in securing the tube to the fittings. Might be okay fixed up on a wall, not so sure in the other ways I've seen conduit used.
I must admit to having reservations about using the conlock system.
However after working with both on a site earlier this year, I can say that the conlock system is much easier and quicker to install.
Good points are that there is no off square threads, no need for cutting grease and no blunt thread dies.
Drawbacks are that it needs some mastic or sealant when used outdoors, you need couplers and adapters (same as with plastic) and people are always losing the Allen keys that come in every box of boxes.
The lengths of conduit we were using were threaded.
