Discuss c-tec nurse call 800 in the Electrical Tools and Products area at ElectriciansForums.net
albi
hi just tryed to replace a call piont only to find the new ones do not work with the old system.
the call piont has a red led sticking out of the top with a red puss button a phono jack and a small reset hole. does any one know of any where i can get hold of any aprox 27 years old
teminals are marked up as S, RC and -
i live in hope:)
try contacting c tec technical speak to geoff it may just be a case you have wrong part.. nursecall 800 is standard conventional and from what i can remember no real compatibility issues, part numbers start with nc, if its qt its for quantec addressable, i have list of parts somewhere
i stand corrected i know the system i used to do were ok, favourite faults were the phono socket breaking or heavy handed nurses with nails breaking the cover over the buttons, but all of these are available spares
what was problem you had?
Reply to c-tec nurse call 800 in the Electrical Tools and Products area at ElectriciansForums.net
So Dad's Old condensate pump went kaput (screeching like a banshee, float valve sticking and wouldn't shut off due to said sticky float valve but...
First off, I'm clearly not an electrician and I'm sure the answer is simple, but I didn't want to go messing with the wires without being sure. I...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
A bit of a mini essay but these questions have been building up in my mind over the last weeks and months as I've been studying and volunteering...
I was called out to a fault today where the newly fitted consumer units RCD was tripping when the cooker was switched on.The cooker had been...
4K
