D80
The new kitchen should then have a heat detector added if its a new extension which should be linked to the other smokes in the house. I havent seen a CO detector that's link able to other smoke detectors. Are all the bedrooms and living room serviced by the other smoke detectors.
Aico's can. But as mentioned before, it's best to use the switch that they do so you can identify which detector is going off.
