We have an interesting project and wondered if anyone else has come across this.
One of my customers, a farmer, pumps his water up remotely from ground source, it is an electric pump housed in its own building, with it's own metered supply.
The pump is running all the time 24 x 7 x 365 to supply the dairy and it's in a big field that he owns, he would like to install say a 50kWp ground mount system to power it. Although the size is irrelavent, it's the principle.
Cable run to the meter is OK, cable run to the dairy impossible.
I can find no definition of 'occupied'
The two possible FIT categories according to the latest FIY payment Rate Table ar Annex 2 from the are:
a) Solar Photovoltaic (other than stand-alone) with total installed capacity greater than 10kW but not exceeding 50kW (32.9p / kWh)
or
b) Stand-alone (autonomous) solar photovoltaic (not attached to a building and not wired to provide electricity to an occupied building) (8.5p / kWh)
Anyone else got experience of this kind of situation, for obviuos reasons 8.5p/kWh isn't doable at this small size.
(and yes we are exploring other buildings as well...)
or
